Power Management Control ECU recall - Dealership recommendation
Fostel
4 hours ago, Saxmaniac said:
Fingers crossed......
Thanks, done already 300+ miles since and no problems at all even hard accelerations are fine, did not pushed exactly to the floor as I am a bit worried if happened again where I am going to pull over but I used a lots of power and the car was ok  Been reading some posts mainly from US Prius chat and over there the guys had similar things happened, different fixes for the different people. I will keep driving it for now. 👍
  • 4 weeks later...
It is true, some dealership does not do a good job on recall, especially if yours is old car outside warranty. In 2017, my Sienna 04 got a free dashboard campaign from crack issue. They did replace the dashboard but the steering wheel was loose side to side. Two 14 mm bolts were not securely tighten and the dealership won't admit their mistake.
