Horn 2019 Rav4
G4HFG Graham
Has anyone tried the horn on the 2019 yet?
Hope it’s not the same squeaky thing, or that will be my first modification.
Cheers.
Our cousins across the pond tell me that it is the ☹️same.
Hi all,
New video review on Carwow of the Excel model, interesting for those still looking,
... and you get to hear the horn.
Overall not a bad review, apart from when he pointed to the heated front wiper switch and said it was for the rear wiper!
Plus, I wish reviewers would at least know a little about the so-called CVT - it's a byproduct of the way the Toyota Hybrid system makes the petrol engine, main motor/generator work together and link to the wheels!  Although, when I've driven cars with a 'proper' real CVT gearbox (with belts and cones inside and lots of other moving parts) like Mk2 auto Nissan Micras, Honda Jazz CVT, and Honda Civic and Insight Hybrids, the way they respond to throttle use feels identical to Toyota Hybrids, even though the mechanics of it are completely different.
He also mentioned the AWD was 4K extra which was not correct of course. Anyway a balanced review in my opinion.
12 minutes ago, Southern Softy said:
He also mentioned the AWD was 4K extra which was not correct of course...
I suspect he took the difference between the Icon (2WD only) and the 4WD Design, forgetting to mention it upgraded spec as well as drive.
The actual difference between 2 & 4 WD in the same spec is just over £2,200.
