2004 Rav 4 XT 3 Denso Altenator
storybookglenn
Hi Guys, have just joined the forum in the hope that you can tell me the bearing numbers or a rebuild kit I would need to replace the bearings in my 2004 Rav 4 XT3 Denso Altenator
so that I can order them and not have the car off the road while I wait on there arrival.
Thanks Glenn
The internal bearings rarely fail but it’s quite common for the freewheel pulley assembly to fail. There are dozens of replacement pulleys available on eBay etc. Check that any bearing type noise isn’t emanating from pulley. This is easily changed in situ.
Yes pully bearings are quite poor on toyotas I've noticed and ac pumps get noisy you can bypass the actual pump if it's that
How do you bypass the AC pump. Glenn
You can a smaller belt from eurocarparts or anywhere for that matter just type in your reg and pick option no ac don't forget the promo code andbe sure to tighten belt because if you don't the beck side will rub on your ac pump
