Auto lights
jorgubb
Is there a way to program drl on the t27 Avensis?I know that on the on the t25 you had to mess with the wiring, is it the same with the t27.
How do you want to program drl's? So that they turn on with the ignition and turn off when the headlights are turned on?
Depending which country you reside in, they may also need to turn off or dim when sidelights/headlights are used.
Well, you will need to check local legislation.
