Unable to lock
David Da Cabbie
Hello
I have a Toyota Avensis Estate 2012 and recently I have been unable to lock the vehicle via key fob or via the door panel switch. I was just wondering if anyone else has had the same problem with their car. Any advice much appreciated, David
Topic title edited
Hi I had a similar issue with mine passenger front door when unlocked would lock then unlock and eventually stay locked had to manually inside car to open door ,item replaced  door lock assembly under warranty at Toyota .
