HI i own a 2012 Aygo ice and would like to upgrade my sound system.
Does anyone have any good suggestions for Speakers?
Hello Adame.
Not too sure whether u want to upgrade your Dash Speakers or the Front door ones, or if u would like to do both?
I will give u some advice, these are the ones that I upgraded to.
For the Dash I used. Em-Phaser ECX100-S6 Coax 2-Wege 10cm / 4'
https://www.amazon.co.uk/gp/aw/d/B0081YOKLM?psc=1&ref=ppx_pop_mob_b_pd_title
For the Front Door Speakers I used. PIONEER TS-E1702is 17CM 2-WAY 280W MAX POWER DUEL LAYER KEVLAR/BASALT CONE
Both two great quality Speakers which will dramatically improve your sound quality.
Will u be using a single din or dual din head unit?
Regards Glen
3 minutes ago, Sweetboy said:
Hello Adame.
Not too sure whether u want to upgrade your Dash speakers or the Front door ones, or if u would like to do both?
For the Front Door speakers I used. PIONEER TS-E1702is 17CM 2-WAY 280W MAX POWER DUEL LAYER KEVLAR/BASALT CONE
Both two great quality speakers which will dramatically improve your sound quality.
Regards Glen
Hi glen, thanks for your reply,
i lifted up the grills on my dash to find they are actually tweeters, i assume i can not just change them for normal 4" Speakers?
Could i just replace the door Speakers with the Speakers you suggested and leave the tweeters alone?
Thanks, Adam
