Wiper blade change
iluvavensis
I have noticed the rear wiper blade on my 2011 rav is splitting but i have never seen this type of fitting before and dont know how to change it, can i buy replacements anywhere ( halfords) etc and i will have same dilemma when the front need to be done, any advice will be welcome thanks
Picture may be helpful.
I has this problem too. Got round it by buying just the rubber strip from local motor factors, and replacing in situ. Not ideal I know, but it worked. saved me faffing with getting the arm off
I found replacement blades / arms did not have to same design / aerodynamics, did want to change the look as it was very neatly done
wyn
i purchased one from my local Toyota dealer where i go for all my servicing. they fitted it for me.
If you lift the wiper up at the joint where it hinges, put your finger between the wiper and the stock put a little bit of pressure and it will pop out
