Warning light/beep for low fuel level?
HSDish
Is there any way to get warning light/beep for low fuel level on Prius+ 2016/17 and Auris TS HSD 2014 ?
Can't find it in our cars.
The low fuel light on the Auris comes on when there is approx 6.8 litres left. Should be diagonally above the 'R' (reserve) of the fuel gauge
For the Prius+ the low fuel warning light comes on when there is approx 6 litres of fuel left. The warning light is to the right of the 'R' of the fuel gauge if you have the multi information display, and to the left of the 'R' if you don't have the multi information display.
4 minutes ago, FROSTYBALLS said:
The low fuel light on the Auris comes on when there is approx 6.8 litres. Should be diagonally above the 'R' (reserve) of the fuel gauge
I'll look moore carefully /attentively . No beep available ?
Don't think so - just a warning light seems to be the case with the Toyotas I've had.
