Sort brake pedal
Richardnowen
Hi everyone
has anyone had a problem with soft pedal after changing brake pads. Nice and solid when engine is off but goes very slowly down when engine running
Hi if you have only replaced the brake pads ,the pads will take a few miles of gentle stops to bed into a worn disc bringing back your firm pedal ,recommend a brake system bleed as well down,t hurt if not changed for a few years.
Edited by Alan1234
More info
Hi, did you find what the problem was? I have the same problem after changing the front pads and have bedded them in and have now changed the fluid and bled the system, still no change. Mine is an Avensis 2010 1.8 petrol saloon.
