Force voice control to select DAB station in preference to FM?
itm
Whenever I use the "station" command to select a radio station it always seems to select the FM version of the station, rather than the DAB version (e.g. for BBC Radio 2). Is there any way to force it to select the DAB version (where available, of course) as this displays alot of useful info about the programme and currently playing song.
Will it not ‘default ‘ to the last station selected when unit switched off ?
incidentally, FM also displays similar station and song information.
The problem isn't at startup, when it does indeed return to the last selected station. The problem is that I am then unable to use voice control to switch to a DAB station.
Hi Ian.
It seems I might have the same set up as you. Is your radio an Alpine?
Regards, Mike.
