Hello all, our engine management light along with low tyre pressure and traction control ligths came on all together, have checked the tyre pressures and all ok, any ideas.
Geoff
See
Thanks for your help, is our car safe to drive until we can get the sensor fixed.
Geoff
Yes. Fuel economy may be affected a bit.
  • 1 year later...
Just bought a 2019 aygo. Tyre warning light came on on the first day. Taken back to dealers who cannot find a fault. No loss of tyre pressure, re set numerous times and still comes on . Weather has been mild, so not the cause. Totally frustrated with problem. Please can anyone help
When you say no loss of tyre pressure, have the pressures actually been checked and are they as specified?
  • 8 months later...
I have this problem did u find a fix
Which problem? Engine management light, tpms light and vsc light together, or just the tpms light??
  • 3 years later...
Geoff
I have a very similar the issue ABS rather than engine management light and the tps flashes for a bit before staying on. Sounds like it may have been a sensor issue but can't see the detail if anyone can help so I can advise our garage when i take the car in 2017 Aygo?
