Yaris Headunit
OOV
hi does anyone know the part number for the adaptor for yaris headunit?
will i need it for wirin amp into standard unit?
ta
or this PC2-17-4 which is the adaptor so the old plugs can go into new headunit
or this FP-11-03 (listed as Rav4 but will fit Yaris) the double din converter from autoleads, which fits into the fascia from toyota?
indeed, and also if you have an alpine headunit like mine you will need another adapter for the antenna lead it is incompatable with the toyota antenna lead, they are both "female adapters" apparently and so dont fit together,
I got an adaptor supplied with my headunit, have a look, so i had a choice of female or male!
its for the wires, will i need onefor wen i wire amp up or will i b able to do it straight up, im wonderin where i wire the remote etc 2 on back of the headunit.
do you still have your headunits instruction manual, cos it has a connections diagram on the back
