Aygo 2 2017 rear seat belt airbag display indicator fallen out
oilit
Hi, First post so please forgive me but:-
I have just bought a 2017 Aygo - and realised the hole in the dashboard is where the display indicator that tells you if the rear seat belts are fastened and if the passenger airbag is on or off is supposed to be.
Now, I have found said display indicator - pushed back into the dash and have managed to get some of that plastic packing strip they use on boxes to wrap around it and pull it back up towards the dash, but I can't get it to stay there - I am guessing it needs to be pushed on from behind...
Does anyone know the easiest way to get up in behind that area of the dash - I have taken the silver surround off the radio console and pulled off the slotted panel that sits in front of the display indicator but that doesn't seem to help as its full of ventilation pipes 😞
Not sure if its possible to get up from behind the glovebox (yikes pass airbag is up there as well 😞
Any help much appreciated
Did you buy the vehicle from a dealer? If so get them to repair it.
