How To: Check DPF Differential Pressure Switch
ConstantinT
Dear all,
I'm having some trouble with my 2007 Avensis 2.0 D4D's DPF and assume the differential pressure switch might Ben the troublemaker.
Could anyone provide data/ information how I can check it? Sensor part number is 89480-20030.
It should be a 3-pin with input voltage, ground and output voltage. Does anyone know the pressure range, the output should reach 0....'input voltage'.
Many thanks,
Constantin
