T25 stereo static/white noise.
matast02
Hi i have a problem where my original stereo is Having static often when i start my car after leasing it for a while. I notice that the static changes/dissapears when i knock on the stereo or press it. Also the sound can get louder if the static dissapears...
 I have taken out the stereo and moved some cables which seemed to help ( for the brief second. Question is, is it the Cables or stereo that is wrong
i was thinking i should try electrical socket spray of some sort but wanted some advice
thanks
Sounds like a poor earth on the radio.  Grab a piece of wire with the ends bared and hold it between the metal radio chassis and a point on the vehicle (bare metal).  See if that improves matters.
  • 1 year later...
Hello. Do you solve the problem ? I have a similar issue and I don't know what to check...
Hello and welcome to the club.
As the last post was two years ago, it will probably be sorted by now.
You should start a new thread for your question.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
