Fuel range
hidecote
Fuel in tank range says 0 miles can anyone tell me why range says zero. My fuel light was on yesterday range said 28 put £10 in but range hasn't increased. Will I conkout, bit scared as I am taxi driver. Thanks
Edited by FROSTYBALLS
Topic title edited to reflect subject
Possibly £10 worth of fuel wasn't enough to "tell" the computer to increase the range?
The range will probably be inaccurate anyway and erring on the safe side too. I only rely on the fuel gauge, more reliable.
Range 0 means the car is running on reserve fuel, which is around 7 or 8 liters.
Thanks so much only had car short while appreciate your help. More fuel should sort it, cheers Jayne
Correct, you probably need 15l before it resets. & yes, the range counts down to "reserve" rather than empty.
