Mitch
Hondacbr600
Hi guys I have Toyota avensis tr 2.0d d4d  mk3 model the car just lost power and that was happening when I picked up from mechanic .I have been left it because was leak of oil through the roker gasket and from the time they replaced the gasket the car stops to run normally. So my question is it possible if the injectors position are changed to do that. There is no lights on the dashboard and no faulty codes on the diagnostic. Thank you very much if someone is able to help appreciate.
