heat shield for 2009 avensis 1.8 zrt27
Browner2707
could someone please help with the part no for the rear exhaust heat shield for my car, I have had a look on line but all the items I have seen look completely different to mine.
I had mine replaced 6 months ago.
The shield is aluminium, but the bolts and nuts are made of steel, so failure is certain to happen.
The part no (for LHD cars) from Toyota is 58327-05030.
Use stainless bolts/nuts, or else the aluminium will corrode away over time and the shield will drop on the exhaust.
Shield costs € 81 excl VAT in NL.
This was the first and only part on my 2010 Avensis T27 ever to fail. 😊
Not because of this event, I recently sold the Avensis and ordered a RAV4 instead.
I repaired mine a couple of months back  -
Look for my repair post.
Go to japan-parts.eu and enter your car VIN number for easier search, after that you should be able to locate the part number you need.
