Heater control panel
Panthor
Hi my 2010 auris hybrid needs a new heater control panel, it has part number 55900-02350.  There seems to be lots available used that look identical but have different part numbers (e.g 55900-02311, 55900-02351 etc) although all say the same model years.
does anyone know if these will work or should I just stick with the same part number. Reason I ask is the one I need is £40 dearer than some of the others.
Just noticied that some of them are the dual system which mine is not so that’s some of them I can’t have. 55900-02351 seems identical though
Stick with your own part number, unless you have extra $$ to do experimenting.
I think you would get a better price if you would contact some wreckers and ask for a price, instead of eBay and etc.
