MPG Display
ferrispedro
2003 2.0 Petrol GX. My display is showing Litres per Kilometer, what is the procedure to change it to MPG?
All you do is press and hold the menu button then cycle through to mpg hope this helps
Sent from my iPhone using Tapatalk
Can you point out the buttons I need to adjust Steven? Ta.
It is the pty menu button keep it held for about 3 seconds if I remember correctly
PTY is for selecting Programme Type (RDS facility)
To change the displayed  units, push TRIP/NAVI repeatedly until the units display appears.  Push MODE/ENT knob and turn to select the required unit set from the three available.
That's the one Ian, thanks. Peter.
