Hybrid Auris 2012 - Brake Oil Flush
yrn11
Hi All,
I would like to flush the brake oil for my hybrid Auris 2012, I know that the back brakes are electronic.
can I use the vacuum pump to flush it? without the need to enter invalid mode or pumping the brakes..
attached is the vacuum pump for the brakes flush.
You must bleed the brakes with a suitable diagnostic computer otherwise you risk damaging the brake booster pump
Not even using the invalid mode? As in the below video
