Rav4 L import
ALawrence
Hi i am mandy just bought a rav 4 L import from japan i am looking for a button key fob for my rav 4 ..as its a import not having much luck has anyone got any ideas of where i could find one any help is appreciated thanks mandy
Moved to the Rav4 club as there will be a better chance of responses.
Have you tried Timpsons?
Car Keys Online are very good.  Contact them here, quoting the vehicle's VIN.
If that key in the photo is a remote key and just has a broken casing, but the module inside is intact, they can probably supply a replacement casing, cutting the key to a photo of the existing key.
Can you photograph the reverse side of the key. Do you have any other keys for the car? Will the car start using the bottom half of the broken key (with the plastic top not near the ignition switch). Do the remote buttons do anything?
