allrate theres a starlet in a wreckers near me which is a rare thing but its dials av a rev counter on them i was thinkin of takin them an puttin it in mine,i jus wondered how hard it wud b to wire up? ive jus sin the guide for a corrola on ere wondered if our connectors wud b the same or if sum1 else knows which connecter it is?
from what i know, the paseo tachometer swap to the tercel will work, but you need to stick with the same era.
for example: 91-94 tercel will work with a 91-94 paseo.
find out what year the EP82 switched to the EP91. and then find out which category your car falls under. (i believe the switch was done from 95+ to the EP91)
