Any suggestions appreciated,just had new injector #2 replaced.runs fine but throwing a code up p062f. Icm eeprom.any one else had same problem.ta.
I think the injector need to be programmed to your car when replaced, that's why it's showing the EEPROM errors, as EEPROM usually refers to programmable chips.
You should be able to do this using Toyota techstream.
Injector code been put in on computer from new one,fired it up then got them codes back,also won’t delete the po62f code.
Moved to the Avensis club.
  • 1 year later...
Injector code has been placed in on the PC for the new one, fired it up then got them codes back, also will not erase the po62f code.
Regards,
Engine Rebuild Kits
