Amp
sup
hello ok i have an 2600watt amp that has 380rms
and i have seen a better looking one that has 600rms but its only 1600watt .
which one would be better? :thumbsup:
600RMS
but it depends on the freq range
Always go by the RMS figures. The peak values are what the amp managed to output a split second before it exploded in the testing lab. They are just for show and don't mean anything in the real world.
We need to know what you are trying to drive with the amp and what the RMS figures are for those devices. :)
heres the spec on the new one:MOSFET Amplifier
Integrated adjustable frequency switch (50 - 250 Hz/12 dB)
Adjustable Input level (0.15 to 3 V)
Bass Boost adjustable levels (45 Hz/0 - 12 dB)
HPF/LPF/OFF switch
Large gold plated power connection
Gold plated RCA plugs
2 ohm stable
Overheating protection
Overload protection
Short circuit protection
Lit up control panel
Dimensions: 63*250*320mm
Max Power (w) 1600
Channels 4 Bridgeable? 4, 3 or 2 Channels
Continuous Power (Watts RMS) 600 Dimensions 63*250*320mm
and here the old one:
Max Power (w) 2600 %THD @ RMS 0.05
Channels 4 Bridgeable? Yes
Continuous Power (Watts RMS) 380 Dimensions 290x310x60mm
High power and Top features.
Housing from milled aluminum
MOSFET technology provides a unique sound experience
2 Ohm Stable
Adjustable RCA Level Input and Output
Ultra Stable PWM (Pulse width Modulated) Power Supply
Inbuilt high speed fan for balanced temperatures
Thermal Protection
Circuit Protection
Remote-on Power
Transient Noise Muting
Turn on delay
Speaker Short Circuit Protection
Gold Plated RCA
380w RMS
290x310x60mm
what do you think?
RMS = Root Mean Square...
This is the current the amp can sustain over constant use, and is a true indication of its power..
As has been said above PMPO is actually useless, and is just for muppets who like to quote HUGE numbers for crappy systems!
What make/model are both the amps? It's doesn't actually in your spec if the rms power is with 2 or 4 ohm load...
come on some one give me an awnser witch is the better amp
1. MOSFET Amplifier 2 ohn stable
HPF/LPF/OFF switch
2 ohm stable
Overload protection
or
2.Max Power (w) 2600 %THD @ RMS 0.05
2 Ohm Stable
Thermal Protection
Circuit Protection
Remote-on Power
Turn on delay
Gold Plated RCA
380w RMS
290x310x60mm
Quick Question on "Le Amp"
The RMS Value. You can power above this can't you? Just not loads.
I got a 1200W MAX with 300W RMS. So maybe 400W is still okay and dont explode. Hehe.
Also cause Im trying to find a 2 Channel Amp that does 350W-400W RMS across both channels!
Maybe Im looking for a mircale.
