best older RAV4 for a carer???
Sweeneywolf
Hi All,
As a carer on a tight budget which older RAV would suit me best for my short stop /start rural and hilly runs in the  snowy in winter Derbyshire Peaks.
Budget is up to 2k so a higher mileage( 150,000?) variant...  2005 ish. ?
Do I go petrol or diesel?
Will do 18,000 miles p.a.
I read elsewhere to be wary of high mileage diesel RAVs
Thanks !
Forget a diesel, because you do short, stop, start journeys.
I just looked on Autotrader and there's a fair few three door petrol auto and manuals to chose from for the budget you mention.
Unless you need the extra space etc, I don't see the point in you dragging a heavier five door option around and using more fuel !!
Look for a tidy one with as much service history as possible.
Good luck.
3 hours ago, BobbyMcLeish said:
Forget a diesel, because you do short, stop, start journeys...
I'll second that.
One of my late mother's carers bought a diesel Astra, and found the Battery kept going flat because the very short hops between clients were too short to replace the energy used to start the car.  A new Battery didn't help, and she ended up getting her husband to charge the Battery at least once a week.
Diesel probably isn’t ideally suitable for your usage, the engine will take longer to reach the correct thermal condition to operate efficiently, a short cold run isn’t going to do that.
