Front brake calliper bolt torques
Tony.Rogers
2004 French built Yaris.
can someone please confirm the torque settings for the caliper pin guide bolts, and the calliper mounting bolts.
also, do either of them require loctite?
thanks
I think the mounting bolts is 88, not sure about the pin guide bolts
I think loctite is a no, I would use anti seize. But I am a novice, never really done any brake work.
Thank you. Is there a separate section in the manual on the brakes?
perhaps the other torque setting I need is in there?
thanks.
Here we go
A few extra pages
Good
Luck
