I have a 2015 Aygo with a standard stereo is there a direct replacement one with sat nav that i can fit please.
Which head unit do you have currently - non-touch screen or touch screen (X-Touch)?
Its not touch screen.
With the X-Touch (touch screen) one can buy a sat nav module for that, called X-Nav.. However, from a cost viewpoint you'd probably be better buying a third party head unit with sat nav, or a good stand alone sat nav.
That's what i thought so i need to know what one is the simplest to fit.I have no idea if there would be any wiring there to work with another unit that Toyota fit.
The plugs used on your car are mostly standard Toyota-plugs (as opposed to the Citroen/Peugeot plugs used on the mk1 Aygo), and its therefore quite straightforward to install a new aftermarket headunit here 🙂
You'll need:
Fascia - CT23TY51 - NB! Max depth of aftermarket headunit is 15cm!
ISO/Steeringwheel control interface - CTSTY006.2 + CTxxxxLEAD that corresponds to aftermarket headunit that you are going to use
Antenna adaptor - CT27AA78
Also...if you'd like to retain the OEM USB-input, you can do so by using the CTPEUGEOTUSB from Connects2.
