Auris 2014 headlight cover
srsoupy
I am looking for the headlight cover of a toyota auris 2014 (pre facelift)
Mine has a crack, is it possible to purchase the plastic cover instead of a complete headlight assembly?
Presumably you mean the lens?
Yes the lens....
Maybe it can be repaired, same way they repair the glass, by inserting some epoxy and forcing it into the cracks, that is if the damage is not too severe.
Afraid not, the plastic lens in heat bonded on and not available as separate parts, you can only purchase lamp assembly
