Door replacement
Anish3001
Hello,
I need to replace my door, I have a 2008 Yaris T2, from which models can I get a replacement door from?
2006 to early 2011
Thx I have a T2 does that mean I have to get one from a T2 or any other trim levels like a T3
I would replace it like for like as the T2 model doesn't have colour coordinated door handles also the internal trim on the door card maybe different so may end up looking a little strange, I would also look out for whether the replacement is French or Japanese, you need to make sure it's the same as yours.
My door card and handle is okay to use can I transfer it to the new door if it’s not from the same trim model?
That fine just be mindful that there could be slight differences between Jap built and French built models.
