Yaris fault
Brandy0712
Hi all I have a 1.33 yaris 2009 have fault code p0338 if I clear it gives p0337 and Visa versa. Battery was shot so replaced changed crank sensor twice still same. Any clues please. Thank you.
Moved to the Yaris club.
Yes new Battery as old one was on its last legs. Tried 2 new crankshaft sensors same fault. They were blueprint sensors.
Hi, have you cleared the fault from your OBD ?? If you have then it seems to be a wiring fault. Check the sensor connection plug first off.
23 hours ago, Brandy0712 said:
Yes new battery as old one was on its last legs. Tried 2 new crankshaft sensors same fault. They were blueprint sensors.
....And is the Battery 'fully' charged, as they don't always come 'fully' charged but with just enough power to get you started a few times over?
Yes Battery new and full been on car 2 weeks now and it does about 100 miles per day. Car starts and runs perfect just same to codes p0337 p0338
1 hour ago, Brandy0712 said:
Yes battery new and full been on car 2 weeks now and it does about 100 miles per day. Car starts and runs perfect just same to codes p0337 p0338
Then that rules that out!
Do you know anyone with a similar car to yours which you could temporarily swap the crankshaft sensor with thus eliminating the sensor entirely? But in the mean time you could try what Bomber209 recommends, that been the connector and wiring to the sensor.
