Old Prius silly non starting problems
homeyjay
On 3/19/2021 at 6:41 AM, PaulDM said:
If you use the key to lock individual doors and hatch not the key fob they will lock.
Once again, what might work on your 2019 Gen 4 does not work on a Gen 2.  For one thing, you can only use the physical key (if that's what you mean) on the driver's door.  There are no key barrels on any other door or the hatch.  Secondly, if you use the physical key, it will only lock/unlock the driver's door.  You use the switch on the inside of the driver's door to lock/unlock the other doors and the hatch.  All this assuming the fob does not work.
On 6/26/2019 at 2:21 AM, homeyjay said:
Can anyone please suggest anything?
Investigate what is going on with the hatch latch and fix it.  It would be cheaper than replacing two, going on three, batteries.
