Reversing Sensors
Notebook
Hi All
Sensors work then don’t etc. If they don’t, by which I mean they continually sound.
Anyway of resetting them etc?
thanks
Is it a Toyota factory kit or an aftermarket kit?
Fair enough, they weren’t standard on the XTR for some reason. If you have a look on the toyota parts site, it will have the fitting instructions/documentation, including the process to short them (to shut them up). My guess is it’s going to be a sensor issue, the obvious solution is to disconnect each one until the beeping stops and then replace the sensor in question. Unfortunately getting a genuine Toyota sensor is going to cost you more than an aftermarket kit would. Also it may not be the sensor.
