How do I get my daytime running lights to work again???
Sent from my Redmi 6A using Tapatalk
Hi Michael, welcome to TOC 🙂
They should come on automatically when you start driving. Not sure about on an Aygo but on my Avensis you need to select gear/release handbrake after first starting the engine before they come on.
Thank you! They used to go on every time automatically, but one day they just stopped!! I changed fuses just in case that was a problem, but seems that they are just not going to work ever again! 😞 Sadly!!! Can anyone else comment on DRL's for Toyota Aygo 13 plate ??? Thank you!  Michael.
Moved to the Aygo club.
Have you checked the bulbs as well as the fuses?
  • 5 weeks later...
On my 2014 Aygo x-clusiv, the DRLs came on as soon as you started the car and stayed on until the sidelights or main headlights were turned on. They were not dependant on gear or handbrake.
