Drivers side window issue - Rubber guide?
complexion
Drivers side window has just stopped moving but the motor is still making the right noises. Took the panel off and I can see that it looks like the rubber guide isn't where it should be. Anyone have a repair guide please? Thanks
Thanks but thats for an Aygo, not IQ. I found this link which contains a repair manual for the IQ in case anyone else ever needs it:
https://drive.google.com/drive/mobile/folders/0B4bpjzCIfWZefkUzaFpiM1U0RXZ4QXc3OERjb1RHSnF4LTdtaWVlYThmRnJodVA0Vk5vZ3M?usp=sharing&utm_source=ToyotaOwnersClub&utm_medium=ForumLinks
After a bit of research it appears it the regulator thats at fault as I thats the rubber I can see hanging. Has anyone ever fixed one of these before?
  • 4 weeks later...
Have you been able to fix it? And what is the regulator?
Hi yes it needed a whole new electric window mech. All good now.
  • 6 months later...
hi, I have the same problem. Toyota diagnosed this.
Unfortunately the parts are very expensive (€450,- excl montation which will make the total costs around €700)). Is there a more affordable way to fix this?
Any itps?
Purchase a window mech from eBay and get it fitted elsewhere for far less as its a quick fix.
  • 3 months later...
Hi guys , first time in this forum, so I have a e11 corolla 2000y and I have been hearing a lot of wind noise, in the car, does anyone knows where can I get new window and door rubber seals, ?
Greetings from Portugal,
