Brake problems
P Khan
Hi wondered if anybody has had same brake problems, I have a hybrid the braking is very slow and the brake symbol flashes for a few seconds. I also has a noisy breaking Each time I take it to the solihull centre they don't seen to think it is a problem. Has anybody got any advise?
If they found no fault with the car than there probably is nothing wrong. Though the brakes can be serviced whether drum or caliper type, cleaned, copper grease in the right places, and red rubber grease on pistons to restore efficiency and aesthetics of the driving system.
With noisy braking and brake light flashing I would suspect worn brake pads.
did you get it sorted out. ?  that place at Solihull gave a glib answer. Brakes are critical.
Caliper condition also might effect the braking performance
