Wiring and clamp connector
David Da Cabbie
Hi everyone, is it possible to buy an H11 headlight wiring and clamp connector because mine has disintegrated and all that is left is the two wires. Any feed back or recommendations much appreciated
ps This was the connector before it broke.
David
Edited by David Da Cabbie
Wanted to be notified when getting a response
Send Parts-King a personal message, detailing your car (reg.no as a minimum) and what you want.
It is possible to get bare connectors and repair wires with the correct terminals, however to do so you need a 5 digit number from the connector, on the headlamp connector the number will be printed/stamped into the connector where the wires enter the connector, if you get this number I can give you the correct part numbers
Thank you.   I will try and look the number up later on today
Hi Devon Aygo I couldn’t find and numbers on or near the connector but here are a couple of photos
Its a PITA to see but it is on the back edge
Hi Devon Aygo,I’ve examined the whole connector and there doesn’t seem to be any number at all unfortunately. Here’s another photo of where I think you mean
Here's the connector list
If the remaining wires in your car are long enough to reach with soldering iron you can just solder any new connector there and isolate wires with heath shrink for example. It does not have to be genuine Toyota connector...
But if those wires can´t be reached, then you may have to go to Mr T.  And I´m afraid the only possibility then is to get the hole new wiring harness inside the front light. Or maybe even new front light?
By the way, have you checked if your dlr reflectors are melted above bulbs? I assume your car does not have led drls?
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
