Avensis estate 2ltr d4d 53 plate
jem555
HI I have standard avensis estate alloys 16 inch is there 17 inch that would fit my  53 plate Toyota avensis estate 2 ltr d4d t3-s
I presume a T25 rather than a late registered T22?
If so, the answer is yes.
What's the size of the wheels I need is it  7JX 17H2 ET 45
i got the juno wheels which are tspirit 17 inch and correct offset etc
PZ474-T0671-ZJ
& PCD for a 2.0 D4D is 5x100
Thanks what would be the correct tyre size for the 17 inch wheels 5X100
Found these its stated to be 5X100 would this fit my car
Are they also of the right bore or at least a bore where you can use an adapter to let them fit? There are plenty of 17" Avensis alloys on eBay etc..
Remember to speak to your insurer as they may consider this a modification & a) not notifying them would invalidate your insurance & b ) they may modify their premium,
Found these wheels 17xjj ET45 42611 - 05150 could someone check to see if they are 5X100
