What Size Fuses
BigGreenKwak
Hi All.
I am due to get my RAV4 Hybrid next week and want to fit a Dashcam. I want to install permanent power cables and intend to use a piggyback fuses for the power and ACC. What size of fuses does the RAV4 Hybrid take.
Thank, Keith
Check owners manual, use electronic version, easier to search.
You can download it from Toyota UK
Been there and done that, it tells you what they all do and what amps, but not what size!!!
Given that most of the previous generations have used mini’s and that each tap will usually cost you less than a quid, which relative to what you have just spent seems insignificant, and they’ll likely come in handy at some point anyway even if they don’t fit, perhaps start with a mini. You can always go old school and connect the 12v to the existing fuse leg. It’s what people did to avoid splicing the loom before quick connects and taps were available.
