Brake caliper bolts, loctite?
StephanEngineer
Hello everyone
For work on the brakes of my Toyota avensis verso I wanted to know if the brake caliper bolts have a specific torque and if you need to apply loctite ?
Any help would be greatly appreciated
I've never torqued a caliper bolt, just double check that they are tight.  I don't bother with loctite either but if they have any sign of Loctite when you remove them, you might want to put them back in the same way.
  • Confused 1
