Has Toyota Avensis 2012 got start/stop technology?
ToNo10
Hi, Has Toyota Avensis 2012 got start/stop technology?
my wife’s 2009 Yaris has but cannot find it on my 2012 Avensis .
thanks.
Not as far as I'm aware. Stop/start was dropped from the 3rd generation Yaris with Toyota citing cost reasons. It continued on the Auris.
Our 2012 2.0 D4-D definitely doesn't have it.
Thank you very much, does anybody know what the ‘shift lock’ button does on the automatic 2012 Avensis 👍
None of the Avensis petrol or diesel have start/stop.
Which engine - diesel or petrol? It's actually a shift lock release button. It should be in the manual.
AFAICT Apart from Hybrids the S\S system was mainly mated to the 1.33/6 speed manual combo in the Yaris Mk2/3 and Auris.
We have it in our 2010 Yaris TR and it has a mind of its own, I tend to disconnect it once I start driving.
A bit of a useless item plus the Battery can cost up to 30% more compared with normal ones.
Sent from my Mi A2 Lite using Tapatalk
It is Automatic 1800 Avensis....shift lock button seems to serve no purpose, maybe it’s a blank?
Thanks y’all 👍
17 hours ago, Shavestick said:
...... the S\S system was mainly mated to the 1.33/6 speed manual combo in the Yaris Mk2/3 and Auris.
Toyota dropped stop/start from the third generation Yaris citing cost reasons.
Correct, the very early Mk3 had it as an option when you bought the French built 1.33 manual or even with the auto cvt but this was quietly dropped in early 2012 I believe, I remember seeing one at Mr T dealership, I think most customers decided it wasn't worth it by that time hence these are very rare.
https://www.honestjohn.co.uk/carbycar/toyota/yaris-and-yaris-hybrid-2011/history/
Sent from my KOB-W09 using Tapatalk
  • 4 years later...
Hi, I have a Avensis 2009 and I have changed the handbrake El. engine.
I changed part's from totally same car and numbers are same.
I get a check handbrake system In display. How do I reset the handbrake system?
Hopefully someone can and will help.
Per
