Horn Part
Gc01
Any one know where i can buy the horn connector for a toyota yaris MK1?
Connector, which end?
PM your chassis number if possible
Where's that?
On your chassis plate or V5 registration document, 17 digits starting with either JT or VN
Access to the parts catalogue needs a chassis number to I.D the car
Can't I just give you the car details?
Isn't it a common crimped on connector. Two a penny from any car accessory place.
No what I need is the plastic thing that goes into the horn because mine got cut off
This, I don't know where to find it as it's not on euro car parts or GSF and on eBay the only place is from Hong Kong meaning it'll take 2 weeks - a month for it to arrive
Free-shipping-1set-Toyota-Camry-Corolla-Reagan-Crown-Highlander-Corolla-Vicki-Whistling-Snail-Horn-plug-wire.jpg
French or Japanese built ?
What engine?
Not sure for the first one and 1.0 petrol engine
Chassis number starts
VN = French
JT = Japanese
OK
Connector
90980-10619
Wire with terminal
82998-12060 ( 160mm long )
82998-12580 ( 500mm long )
Orderable from your local Toyota dealer
Inside the uk because the only toyota part centre I can find is in america
Your local Toyota dealer
Hi Chris.
Try this man, if he can't help you I am sure he can point you in the right direction.
He has a few names;-
The Parts King
Kingo.
John Devlin
Phone no. 01244 821031
It is a main Toyota dealership call Lindop so you will have to ask for him by name via the switchboard
You are welcome to say I gave you his contact details
Mike169
Thanks I'll give him a try when I have time
Hi Chris.
He works normal works hours not forgetting it's a main dealership although I am unsure about Saturdays, most items he will send through the post.
He is the best you just have to give him your reg. no.
Mike.
