Avensis T3X 2004
Deb F
I have a problem with the lights
Tail lights, side lights all out. When lights are turned on to main beam, front side lights come on but still no tail lights.
All fuses and bulbs have been checked, new stack fitted, (today), STILL NO LIGHTS.
Has anyone , any other suggestions.
A bit of methodical checking of voltages and ground resistances using a multimeter should get to the bottom of this.  Random guessing is not much help. The lighting circuit on these cars is quite straightforward and conventional.
Hi, have you checked to make sure you have a feed coming up the wire that feeds them? Mike.
