Zex Nitrous Kits
sup
hi guys any one intersted in a ZEX Dry/wet Nitrous Kits im just talking with a guy who says he can get them for around £499 heres some info
ZEX NITROUS KITS ARE DESIGNED TO WORK ON STOCK AND MILDLY MODIFIED SYSTEMS WITHOUT ANY FURTHER MODIFICATIONS TO THE FUEL SYSTEM, ETC. Once armed, the kit is activated only when you are at wide open throttle, further ensuring engine safety. 55-75 horsepower can be easily added, and up to 125 horsepower in certain applications.
The Zex kit is simple to install. If you are familiar with basic tools and have a few hours of time, you can install the kit yourself. Otherwise, most local speed shops will do the installation for around £150.00. If you choose to install the kit yourself and find yourself in a situation that the detailed installation instructions cant help you with, Zex has a call free installation help number you can call to speak with a live zextek.
Zex Kits fit most all sport compact cars, and many other applications. To determine whether or not Zex will work on your car, find out if your engine has a vacuum ported fuel pressure regulator. You must have one for the zex dry kit to work on your vehicle. Vehicles with a returnless fuel system have to use the Zex wet nitrous kit.
Zex Kits come with everything you need to install nitrous on your vehicle including: Nitrous management unit, 10lb bottle, nitrous nozzles (55,65, and 75hp), arming switch, all brackets and mounting hardware, and delivery lines.
what do you think? :group-cuddles:
but does the yaris have vacuum ported fuel pressure thing??
if you look in for sale ive got some zex stuff for sale including all the bottle opener, purge kit etc.....
yer im not sure about the vacuum ported fuel pressure thing but if it dont he has the wet one . is that agood price thou?
price is on average
it aint cheap and it aint expensive
but remember ur not just buying the nos tho, you will need to upgrade ur car in different ways aswell to cope with the nos
yep like bigger brakes, and possibly stiffer suspension. (and maybe a parachute out of the back as well) :lol:
