Dropped magnet inside dashboard
Juandan
I dropped a magnet inside the dashboard while trying to retrieve a 10mm socket that dropped inside the dashboard while I was installing a radio,
will It be alright to leave the magnet inside or could It affect the electrics in the car. thanks
It’ll likely be fine and stuck to a ferrous metal object, but it’s still a good idea to find it/remove it if possible.
 I must of loosened some connection while I was putting the unit  back in, because the rear reverse camera stopped working,
I've tried all the connection but no luck, I'm taking it in to the car Audio centre tomorrow.     Thanks for your reply.
