Got a Vogtland suspension kit this week but have realised I need new top mounts, along with the seal that sits between those and the plate above the top of the front springs. Any ideas on part number or links for cheap parts? Could also do with the plate above the spring due to corrosion, but hopefully cheaper than £18 which Toyota quoted.
Also, I am a little unsure on the set up of the rear shocks. Am i correct in thinking this is the part I need for top mounts, and nothing else:
https://www.autodoc.co.uk/tedgum/8534193
Do the rear shocks have bump stops and dust gaitors also?
I rang Toyota today regarding the front mounts etc and the prices are just silly, around £120 per top mount.
