Celica T-Sport rattle when accelerating
Ashtonm00
Hi all,
I have just become the proud owner of a 2003 facelift Celica T-Sport. I have noticed that when accelerating, there seems to the a slight rattle which I THINK is originating from the right-hand side of the engine bay (right-hand side from sitting in it, so ...front off-side?) but I couldn't be certain. I suppose I need to test it does it in neutral then pop the hood & pull the throttle cable.
It almost sounds like a loose chain kind of rattle & is more apparent when accelerating slowly or say creeping up a steep hill slowly where minimal power is required. When on full throttle, it's not really noticeable.
I am wondering if it could be the timing chain tensioner perhaps? I think that may be on the opposite side of the engine though but again I am not absolutely certain which area it's coming from. I know factually that it's definitely only when applying gas & more pronounced at low RPM.
The car seems fine otherwise - no knocks or rattles, tight & pulls well. LIFT definitely engages but definitely doesn't seem as brutal/Jekyll & Hyde as I was expecting!
Any thoughts would be good. I can try & get a recording of it. I need to check if it does it in neutral also.
Cheers.
Ash
