Installing Sun visor Clips
Haitham Mohamed
I have a question
while need to remove the sun visor so basically need to remove everything holds the headliner but the problem is the sun visor clips i broke them until i had found that the service manual says by rotating them 90 degree counter clock wise it will release so if i wanna to install new one , so i will need to install them at 90 degree and rotate it or just install it straight without rotate it ??
Hi Haitham.
Pure logic feels you put them on 90 degrees counter clockwise then turn then 90 degrees clockwise assuming the part they twist onto is in good condition.
Regards. Mike.
What happen if i install the new part straight up like the clips without rotate them?
Hi Haitham.
Hi, they might not stay on. It should be a simple job just try it and come back to me if you get into troubles preferably with a photo if at all possible.
Regards. Mike.
