Add Cruise control on Avensis 2010
Duratec
Hello,
i install a cruise control (oem) today but it don’t Work (and no light on speedometer).
The plug is ok and well Wired on the ECU.
have you an idea to activate the function ?
thanks a lot.
it’s a 1.8 vvti petrol, 2010, dynamic. Automatic multidrive
which engine?
Hello Heidfirst,1.8 petrol 2010, automatic gear multidrive
Update today, on fact, the cruise control work perfectly but no light on the speedometer. May be missing a led or Two.
Well done for successfully installing the cruise control. I assume you have driven on the road and tested every function works properly - set cruise, +plus to go faster, -minus to go slower, brake pedal or pull back to disengage cruise, and resume to go back to previous cruise speed.
For the benefit of others, there are two indicators that illuminate when using cruise control. One is the same symbol as the stalk control, which shows the system is active, and the second is the word "SET" when the cruise control is in use. The only issue would be if the driver has turned off cruise control completely and tries to SET/Resume cruise!
I assume the lights all being LED and not old bulbs, means a more involved way to get them working. Now assuming Toyota use the same instruments for the all petrol models (except mph/kph markings), then it could a case of getting a signal to the CC indicators. If not all the same for spec levels, then it could be a change of instruments.
I think you need to get the wiring schematics to see what you need to do.
My car being the TR came with cruise control as standard, along with other extra kit over the entry level T2 model.
Look at this UK brochure and you see why:-
Avensis-June-2009_tcm-3060-363527.pdf
