Issue with gearbox
Kavish
Hello,
I got an issue with my gearbox. After diagnosis, the two errors below were found:
P0746: Pressure Control Solenoid ‘A’ Performance or Stuck Off DTC Trouble Code
P0776: Pressure Control Solenoid ‘B’ Performance or Stuck Off DTC Trouble Code
Has anyone ever faced this issue?
Thank you.
Hi
Have you checked that the ATF level is not low and does it appear dirty at all? These two instances will put the error code you are having as would having metallic debris obstructing the mechanical function of the solenoid.
On 7/30/2019 at 6:11 PM, Kavish said:
Hello,
Thank you.
